1 - 14 of 14 Posts
I want to order a test pipe to remove the cat converter and get a 02 bung for my wideband. My question is, does anyone have issues with the AMS test pipe with it rubbing on the drive shaft or any other parts? I been looking at the ETS pipe and it has a bend in it claiming other pipes wil rub. However with shipping the pipe from ETS comes to $387 and if i order from AMS its only $280. (mostly all the difference is in the shipping)
dude if you dont care about brand names you can always go with the rexpeed. I got mine 110 dollars shipped to Fort Mcmurray, piece looks good and still looks good after a month or so. Comes with extra bung for wideband and doesnt rub ( it has the bend in it). You can ask weebles as well as he helped me put it in, it looked like a great piece especially for the price. Also speed was great. I received it in like 4 or 5 days.
I have the ETS test pipe and I really like it, no exhaust rattles at all. But I'm sure the other ones mentioned are good as well. However, I suggest you get your wideband bung in the downpipe instead of the test pipe, are you planning on getting a downpipe?
Discussion Starter #7 (Edited)
yea im getting a dp as well. That was a question i forgot to ask. Assuming you remove the cat, does it matter where it goes (on dp or on tp)...and why.
In most cases i believe you get what you paid for. Not knocking the other companies but i feel abit un-easy about buying a test pipe that is only $110 from one shop but from a place like ETS/AMS its 2x the amount.
Purple meat eater
In most cases i believe you get what you paid for. Not knocking the other companies but i feel abit un-easy about buying a test pipe that is only $110 form one shop but from a place like ETS/AMS its 2x the amount.
You are absolutely right on usually getting what you paid for, and to pay over $200 on a piece of pipe with flanges and bungs welded to it seem a bit excessive.
The CAt conv or test pipe is no where near any driveshaft. No chance of rubbing the drive shafts.
A cat-back system, possibly but not a cat or test pipe.
It's best to put it on the DP, the reason being is that you get a more accurate reading which is somewhat important when it comes to AFR's, its not a huge deal if your just doing basic bolt ons and putting it on the TP but I would get it on the DP just in case you go for a little more in the future. It doesn't hurt to be more accurate.
I'm with you to be honest, especially with our shitty winters I'd be a little hesitant to buy a $110 TP good or not. With ETS I've driven it through one winter and I have no rusting and the welds are in good shape. Its a great TP, do it right the first time imo.
Discussion Starter #13
Just picked a T1R Resinated Test pipe from a local member for $100. Will there be any issue with fitment on stock dp and stock exhaust since it will go 2.5" - 3" - 2.5" ?
Discussion Starter #14
Just installed the pipe, no issues getting it in. Did anyone else reinstall the heatshields? They do fit around the resinator but i left them off...although im worried about the sensor wire hanging below the pipe.
1 - 14 of 14 Posts
