Okay i figured I would finnally post up a bit on my car. My original engine feel victim to lean under boost since I did not want to buy a fuel pump relay and it was bad. It got replaced under warranty but that was a headache so I decided That my car needed more then a uicp and the ERZ exhaust. I replaced the turbo with a ported FP Red, evo dynamics 3port and dw850 injectors along with a act street disc. Next up was a robispec rear sway bar and amr coilovers. Then I traded my 850s for some dw1300s and bought a dw fuel pump from map along with the install kit. About a month later my crank pUlley came apart and my drivebelt went into my timing cover so I knew I would have to build the engine over winter but proceded to flog on the poor thing. Next up was the act street disc was slipping so threw a 6 puck in which faired no better and my cmc broke at autocross. I had the magnus adapter so installed that along with a rewelded UR downpipe, modified Ur fuel filter kit, boomba fuel rail, whiteline front sway bar, whiteline rollcenter kit, along with driveshaft bushings, diff bushings, shifter cable bushings, ssp sway bar links, kelford 214a cams, supertech valve springs, center diff pins, boomba front motor mount along with some other little parts. A few weeks ago I went on and did the rest of the stuff to the car. so now the car has k1 rods, wiseco 86.5 pistons, arp headstuds, mildly ported head, ported exhaust manifold, cnt v3 catback, depot hfc, fuelab regulator, exedy twin disc omni 4bar map sensor and Maps 3.5 intake. Hopefully this time the car is happy for a bit.
replacing my diff pins.
Measuring rod clearances and building engine in the living room.
Bored at work so i decided to work on the head.
All back together again
