from some tuners for you
( there is a difference between a MAF and the MAP sensor... )
I'm quite aware of the differences between a MAF sensor and a MAP sensor. So you do know that our cars have both sensors as a stock setup, correct?
Post that in the other VTA threads. Nobody else is posting logs, just videos that don't prove anything.
Well wait a minute...you were the one saying that it goes rich when you're on the throttle...
Now you're changing your story and going with the off throttle rich condition argument? The video absolutely proves that VTA doesn't peg the AFRs rich when you make a pull, which was your original argument...which really never made sense to begin with since the BOV is sealed shut when you're on the throttle.
Is a line across a graph going to show you something completely opposite of what the actual gauge is showing you? Probably not, but my apologies for not getting you a squiggly line...I don't carry my computer and Tactrix cable around with me everywhere I go.
And I'm not really sure what I'm looking at in that log graph...it looks like a big jagged line with one point picked out labeled 10.3 AFR. It doesn't tell me what else is happening with the AFRs throughout the whole graph, it doesn't show how the pull was made...the throttle position is all over the place... and it doesn't tell me what a recirculated valve will do in that exact same situation.
I helped a friend tune his car when he was still learning what all the tables do. He has a recirculated valve. There were several times you could sit there and watch the gauge running 11's, and then he'd let off to shift and it would take a quick stab into the low 10's before getting back on the throttle. So again, showing me one point when a VTA hit 10.3 off throttle isn't proving much...
I'm an open minded guy, and if it was a clear cut WOT, shift, WOT, shift, etc. and it showed AFRs going stupid rich compared to a recirculated valve on an identical pull, then absolutely I'll agree with you 100%. But a few squiggly lines with with no way to read them tells me nothing. The video shows RPM and AFRs, and you can clearly tell it's a WOT pull to redline...and I also posted a part throttle video before, with the gauge immediately swinging more lean during shifts instead of rich...not sure how you can get much more clear than that...
Forgive me, but I'm not the kind of guy that sits here and listens to everyone else and takes it as gospel. If I want to know if something works, I'll go figure it out myself. Just because I don't get paid to tune cars, doesn't mean I don't know how, or how everything works.
Also, I have no disrespect for anyone here, especially Clipse and some of these other guys who have produced some awesome tunes...as far as I'm concerned this is a friendly debate...
...with maybe a few smart ass comments thrown in...my bad..
