1 - 20 of 66 Posts
· Administrator
Today we will be reviewing a few Torque Solution products sent to us from our Elite Merchants, South Side Performance (SSP).
We have three products featured here - shifter bushings, a short shifter, and some exhaust hangers.
Without further ado:
Torque Solution Short Shifter
By: Kidneythief13 & Nohan
Edited by: Kooldino
What's in the box:
Hardware & short shifter.​
Install time and difficulty: Just about 60 minutes, had I not run into a hitch with the supplied 7/16" shift boot retainer. Install is really quite simple, provided you have the right tools. Read below for details.
Price: $134.99
To Order: http://www.sspperformance.com/products/product_info.php?products_id=156
Product Description: Machined from 4130 Chromoly steel. The short throw shifter is a direct replacement for your long throw stock unit. The unit reduces throw by 32% & height by 1.25". It is compatible with stock and aftermarket shift knobs & changes the factory offset to center shifter closer to the driver.
Thoughts and Impressions: I recently obtained and installed a Torque Solutions short shifter and the following is my take on it. Hopefully the review will be helpful for any others who are in the market for a short shifter, or for that matter, anyone who is trying to decide which part to get next. My Evo X GSR is the first performance car I’ve ever owned and I’ve never driven a car with a short shifter before. I’m not experienced with installing mods nor am I what you might call “mechanically inclined.” Some might think this to be a bad thing, perhaps hoping the reviewer was someone with more experience on the matter. However, due to these circumstances, you’ll be getting a review from a normal guy without any bias.
Before you can use the short shifter, you’re going to have to install it! Although I found the project to be a little intimidating, the install was surprisingly quick and easy. To start, I found a “how-to” file online – a step by step walkthrough with pictures. The directions were straight-forward and easy to follow. In the list of tools required, they recommended that you have a Dremel. Well, let me just say that you don’t want to attempt the install without one, it was extremely helpful.
Obviously, the stock shifter has to come out first. In order to do so, you have to remove a couple of push nuts. The directions say you *could* use a screw driver and a hammer to pry them off. But that is most likely a total pain. If you have a Dremel handy, this step is quick and easy.
In total, the install should have taken about an hour – except for one minor hitch. I had a problem with the part referred to in the directions as the “special shift boot retainer.” It was basically a metal disc which was supposed to slide down the shaft of the shifter, once in place, there was a little screw you could turn to keep it stationary. This part is meant to ensure the top of the shift boot stays where it’s supposed to.
“What’s the problem,” you ask? Well, the hole in the center of the shift boot retainer wasn’t big enough! There was a spot on the shaft of the shifter where the threads got thicker. In the directions, you are supposed to be able to slide the retainer past the thicker threads. Try as I might, I could not get the part to slide down far enough. I even attempted using my Dremel to grind the hole larger, but it was to no avail. Was I just unlucky? I don’t know, but that was definitely frustrating. With a little improvisation, I figured out that I could just use a small worm clamp in place of the shift boot retainer.
worm clamp quick fix:
Once I got everything put back together and screwed the shift knob on, I was blown away by how great it looked. I know that some companies sell shift boots made especially for short shifters, but it really isn’t necessary. I think the extra bagginess of the boot is really nice. At this point, I was happy with how it looked, but how did it perform?
It felt quite odd when I reached to put the car into gear, I didn’t realize until then how much shorter this shifter was. After a very quick adjustment, I soon came to appreciate the reason why people get short shifters. The time it takes between shifts is dramatically reduced. The specs say that shifts are reduced by 32%, but it felt even faster. I’m sure my weighted shift knob helped, but the shifts were smooth as butter. As I drove around town, I actually looked forward to red lights (that’s a first). A red light meant I got to run through the gears again, which I was really having fun with.
For those who want a simple breakdown, or for those who were too lazy to read the review, let’s recap:
Pros:
Overall, the install is pretty painless
It looks great
Shifts are lightning quick
Shifts are nice and smooth too
Cons:
Had trouble with the shift boot retainer
The Bottom Line:
If I didn’t have the issue with the shift boot retainer, I would easily have given this short shifter a 10 out of 10. I haven’t had it very long, but I can already tell the short shifter is one of my favorite additions. The bottom line is - if you’re driving without a short shifter (and weighted shift knob) you are missing out!
Emoticon Rating: :thumbup:
· Administrator
Discussion Starter · #2 ·
Torque Solution Exhaust Mounts
By: Stock?
Edited by: Kooldino
What's in the box:
Install time and difficulty: Approximately 1-2 hours depending on how you choose to install. I would definitely have a can of WD-40 or soap, something to help slide them on. The installation is not very difficult.
Price: $44
To order: http://www.evoxforums.com/forums/showthread.php?t=39375
Product Description: Torque Solutions Evo X exhaust mounts will greatly reduce exhaust movement and vibrations, both under extreme racing conditions, and daily street driving.
Thoughts and Impressions: My first thought was that these were VERY solid/well made pieces. Once I started installing them I realized that doing this install in the cold weather was a bad idea, I took them inside to warm them up a bit. After they were warmed up a little they were much easier to install but it still takes some elbow grease, fitment was perfect.
My stock exhaust mounts were starting to "Sag" a little and cause vibration and rubbing on my o2 dump. The alignment of my exhaust tips are perfect, so far I have little vibration while normal driving, and it is no longer rubbing on my o2 dump. :)
The Bottom Line: I have zero complaints with these mounts (Other than the install difficulty), honestly for $44 you can't lose!
Emoticon Rating: :workout:
· Administrator
Torque Solution Shifter Bushings
By: Daemon Sadi
Edited by: Kooldino
What's in the box:
Install time and difficulty: 30 - 45 minutes, very easy. You have to remove a bunch of stuff to get to the bushings, but it’s all very simple stuff. Torque Solution deserves some props for the clip design they use in order to get the bushings in easy and quickly. You will also need a Dremel Tool or something else to do some simple plastic cutting. More on that later.
Price: $26.95
To Order: http://www.sspperformance.com/products/product_info.php?products_id=126
Product Description: Torque Solution engineers to ensure product performance and reliability while drastically reducing shifter end play allowing for crisper, more precise shifts. All this makes it easy for us to stand behind our shifter bushings with a lifetime warranty.
Thoughts and Impressions: After driving around with the new bushings for about a week I will say that I am satisfied with them. 1<sup>st</sup> – 2<sup>nd</sup> gear shifts seem to be most noticeably better.
My only two problems with this product occurred during the installation. First of all they did not come with instructions of any kind. While these are simple to install and you can find other instructions online, it still would have been nice to include some.
The second problem is that the vertical bushing had way too much wiggle room when I initially installed it. I had to get creative and Dremel off the long end of the plastic clip that held the stock bushing on. After that I re-used this piece AND the washer that was initially on the other bushing in order to stop this wiggle room. With these modifications everything fit snug and worked great.
The Bottom Line: A good product for a great price if you don’t mind a few D.I.Y. adjustments. The oversight on the size the bushings is questionable as is the lack of instructions.
Emoticon Rating: :drive:
right on!!! I have been toying with the notion of getting one thanks SOLD!!!!
· Evos before hoes
How well does the exhaust hangers work? For I dont want my exhaust to be banging around anymore will this hold it in place?
I've bought the exhaust mounts and was wondering which holes you used when hanging the exhaust? Do you have a picture of the hangers installed? I believe I installed mine incorrectly as my exhaust is hanging a lot lower than with the stock hangers.
Well that's what I did and I had to squeeze the metal prongs on the exhaust with a lot of force in order for them to be narrow enough to fit into the bottom two holes. Also I couldn't even hang the drivers side properly. Only hanging through one of the hanger holes. The exhaust doesn't hang evenly and is a lot lower. I would just like to see pics of his install. BTW I am using AMS exhaust which should fit these mounts.
Anyone have these exhaust mounts and willing to take a pic for me? Just so I make sure I haven't done this incorrectly. Here is my set up. Look at the gap between the exhaust and the bumper and how it's slightly off center.
just letting you know bought the short shifter yesterday now just waiting thanks again!!!!
1 - 20 of 66 Posts
