11 gsr self tuning noob - Tp, Cbe, intake, uicp, GM 3 port and crushed BOV
Is the ECU tuned properly after installing the 3-port? Please note that WOT must be done after tuning the ECU to fit the 3-port. If not, the boost pressure will be excessive.So I've switched over to a 3 port and now when I go and log files and do a WOT I see the wgdc go from 30 to 113
Ok got it I'll make sure to do that. Bin self tuning myself so just following everything I can that I find on the forms and followings Merlin's guide. I just got the rax program today since mode23 wasn't really working out so good for me.Is the ECU tuned properly after installing the 3-port? Please note that WOT must be done after tuning the ECU to fit the 3-port. If not, the boost pressure will be excessive.
Ahh ok cool thanks. Now I'm chasing a lean out WOT throttle where I'm hitting 16-17 on WOTAnything over 100 is still considered 100.
I have a aem wideband. I don't know about how to log the wideband with a SD cardBy chance do you have an Innovate Wideband gauge for logging AFR onto your tactrix? I can't seem to log AFR to the SD card with my AEM X series that i wired a 2.5mm jack from the guage.
I know I wired it correctly cause i can log my AFR on my laptop when I plug the 2.5mm jack to a RS232 DB9 to USB. but would love to be able to just standalone log that to the SD card.
