1 - 11 of 11 Posts
· Premium Member
I don't think it's anything you NEED, but can definitely see the benefits I suppose. I thought about ceramic coating mine, but decided to only do my ex mani.
This mixed with a manifold shield would help lower intake temps a fair bit. Because of the setup of the turbo, charge air temps are extremely high. I would like it Perrin would bring out their manifold shield.
"We are onto the 3rd version and so far we have gotten a huge drop in surface temps on the turbo, like 400+ degrees on the surface!"
Here is the link for the shield
http://www.evoxforums.com/forums/showthread.php?t=5968
400 degree drop just from covering the manifold than add in a turbo shield that could mean some serious temperature dropping and nice gains from the cooler air
That thread was from 08, did they ever produce anything regarding the heat shield.
lil bump bump in case perrin can see this thread lol
Discussion Starter · #8 ·
Due to many turbo kits and manifold designs, you can't get a one heat shield to fit them all, i guess ceramic coating and additional heat wrap is the only way to go.
Anyways i contacted DEi and they said it's not meant for stock turbo, but T25/T28 might be a good fit.
· [Local Team Member], aka pimplay2
good post never seen this from perrin
I use a DEI heat sheild, on a 6266 vband turbo. Note that if you're getting one of the larger 35r turbos, you need the t4 blanket from DEI rather than the T3 blanket.
Fits great, and I love dei products.
1 - 11 of 11 Posts
