Hi, I’ve got some unpredictable understeering. My alignment is toe=0, camber: front - 2° rear -1.5°.
I’m on snow tyres, Nokian WRG2. Road condition: moist... not dry, not full wet, no mud, no ice (temp 41F).
I call it “unpredictable” because it happen when it shouldn’t. Slow corner (20 mph), not in high speed corner because I’m very careful, but I think it will be the same.
In normal driving, I brake before the corner than I leave the car go, no brake or throttle. In tight and slow corner I’ve got this bad surprise...I wrote bad because the understeer happened at low speed and I was totally unprepared! It is really noticeable, the car seem shaking, a part from not cornering well.
I’ve done some tests, same corner and conditions: if I brake to have the same entry speed (20 mph) and then I apply some throttle, (thanks to S-AWC) the car turns really well, perhaps slides a little but it’s really predictable and the cornering speed is higher than the case where I brake and I let her go without throttle.
The problem is that when I’m in spirited driving mode, I can expect some reactions like understeer, oversteer and I’m prepared...but in case like the other day, I was driving relaxed, the entry corner speed was slow and the high understeer scared me! You know before entering a corner if the speed is right to avoid problem, to have perhaps problem or to have big trouble...I was in the first case.
I thought to rise the front tyre pressure but It seems me to be high: 35 psi front and 32 rear. Is it correct? How can I reduce the problem?
Thanks
Thanks
