So I just installed a Cobb cat-back and Stage 1 tune with the AP. Last night at full throttle the car violently cut-out at around 4-5k RPM. It did this in 3rd gear first and then immediately again in 2nd gear at full throttle. It feels like fuel cutting out. Unfortunately, I was not logging at the time.
I have read all about the fuel pump relay going out, and I have also experienced some full throttle hesitation issues before I made any modifications to the car (always thought it was full starvation after hard turn).
I know the problem presented by a failing fuel pump relay is running lean, but I haven't read about it causing fuel cut-out. Is it possible that the fuel pump relay can be the cause of the cut-out issues i experienced last night. If not, I have no idea what to think!
