Filed under:
Tech,
Volvo
Volvo is joining the ranks of other automakers by beginning to offer a dual-clutch gearbox to the masses. The new transmission, developed in cooperation with Getrag, features six-forward gears and reverse, and opts for a wet-clutch system like the first generation VW/Audi setup. Aside from the obvious performance advantages gained by quick shifts, Volvo estimates that fuel consumption will be reduced by around eight-percent.
The new setup can handle over 330 lb.-ft. of torque, something that has proved to be an issue with similar setups because of the small surface area of both clutches. When Volvo's Powershift transmission debuts, it will initially be equipped on the C30, S40 and V50 fitted with the 2.0-liter turbo diesel. There was no mention of what models in the U.S. could benefit from the new 'box or when it might be available here in the States.
Volvo's full press release is posted after the jump.
Continue reading Volvo's answer to DSG goes by the name Powershift
Permalink |
Email this |
Comments
More...
