It's strange that your barometric pressure readings are fluctuating so wildly, especially since the barometric pressure sensor in the MAF should provide a relatively consistent reading as atmospheric pressure doesn't change that quickly or dramatically under normal circumstances.
Given your description, a couple of potential issues come to mind:
1. Faulty MAF Sensor: Since the barometric pressure sensor is located in the MAF on your Evo, a faulty MAF sensor could be causing inaccurate readings. You may want to check the wiring and connectors, clean the sensor, or potentially replace it if it's faulty.
2. Software Glitch: It's possible that there might be a bug or glitch in the software you're using. Try using a different software, if available, or updating/reinstalling your current software to rule out this possibility.
3. Incorrect Parameters: Make sure you're reading and interpreting the data correctly. Make sure you're using the correct units, and that the software is correctly calibrated for your specific vehicle and its sensors.
