1 - 5 of 5 Posts
Hi guys
Just picking this up and needing to have it re dyno’d what’s a safe whp I should be able to expect?
Morley 1000hp rods in it but the camtec 260/268 is what I can’t find info on as the company is no more.
Anyone done a similar build?
Font Parallel Pattern Number Paper
Font Material property Paper Document Paper product
Those HKS injectors are going to run out of fuel around 460hp but can be pushed to around 500hp at 100% duty cycle. Just remember 460hp on a Dynojet is probably 350hp on a Dyno Dynamics.
Just make sure the tune is smooth, your tuner keeps the TQ down for the SST, your AF numbers are good, and the tune isn't pushing 100% IDC. That's a solid build but it's not a big numbers build so don't push it.
Discussion Starter · #4 ·
Not pushing for crazy numbers just want about 400 at the 4 and safe reliable on the rollers not hub as the clutch packs are only rated for 500. the old dyno chart leans out on the fuel a touch at4700rpm will get that fixed up and change out the hks injectors so they are not pushing their limits possibly a new fuel pump to recon that would be doable without fireworks going off? Cheers guys
1 - 5 of 5 Posts
