whats up guys i currently have my subframe out of my car and so i figured id replace the front sway bar while it was down and out... anything else i should buy while everythings apart? im already buying the RCK .. what do you guys think
off top....got all motor mounts already... and only doing the front right now because the front is taken apart so i was looking for what 100% to do while im already in there
Not that bad, I have 75 duro on all but the rear, so 3 mounts.off top....
how bad is the ride quality with all motor mounts?
It isn't that bad.From what I've heard, a pretty awful ride.
Same here, on cold startup or rolling from a stop, ~1200-1400rpm, there is a lot of dash rattle. Once you get cruising it isn't bad at all, a little louder in the cabin but that is it. When I dig out of a corner hard there isn't any wheel hop or wha, wha, wha, whaaaaaa issues anymore. The drivetrain geometry loves it! :thumbup:I have the AMS front mm with the 70 rated (red) bushing. It vibrates the entire cabin on start-up and a little bit when idling. Engine loves it though :rock:
