I did so searching on the forums not really finding what i want to know about the WGA, did enjoy reading post bashing this guy for getting tune then installing his wga..anyway im going to be running stock turbo for while ans was at toss up on the WGA. really want to understand the ratio of the spring rate / the Boost your going to be running, meaning 25+psi need an wga spring 25 psi. im planning to run 24-26 psi on stock turbo/ 93oct with full bolt on's w/ out any fuel mods i was thinking i would be better running a spring that will open 19-20psi just to be on the safe side.
wanted to know what spring rate would work best with my setup.
believe forge has 19-24psi
FP has an 18psi or 25 psi
or should i just adjust the stock wga believe can mod it to hold 17psi
