1 - 20 of 34 Posts
Whats UP Chico's what we need to know:
WheelS:
Wheel Size:
Tire:
Tire Size:
Spring/Coilover Spec (Optional)
Picture:
GO
Discussion Starter · #2 ·
bump mother fuckers!
Don't want you to get lonely in here Navy :)
Wheels: Work Emotion CR KAI in Matte Gunmetal
Wheel Size: 18x9.5 +20
Tire:Cooper Zeon (I know I know but I was on a budget)
Tire Size: 265/35/18
Spring/Coilover Spec (Optional): None yet, waiting till I move from Alaska this fall
Picture:
Wheels: TR Motorsport MT1
Wheel Size: 18x8.5 +35
Tire: Bridgestone Potenza RE 760 Sport
Tire Size: 245/40
Spring/Coilover Spec (Optional): BC Racing 8k F/6k R heights are adjusted to BCR factory default for the front and +0.75" from BC Racing's factory default on the rear.
Picture:
****These pics were taken with H&R "Sport" springs on the car ... The car currently sits ~slightly~ higher on the coilovers...
Teaser
WheelS: XXR 521
Wheel Size: 18x8.5 +25
Tire: Nitto NeoGen
Tire Size: 245/40/18
Spring/Coilover Spec (Optional) Tien Springs
Picture: Teaser
HERE IS THE ASS PER YOUR REQUEST. I think i need to go to 18x9.5
Cunning Linguist
Tire Size: 245/40
Picture:
Best setup I've seen on an RA, hands down. Props to you, sir.
Wheels: Tenzo Racing, Cuzco V1
Wheel size: 18x8 +37
Tires: Falken F452
Tire Size: 235/40/18
Springs: H&R
Wheels: Tenzo Cuzco V1
Wheel size: 18x8...can't think of the offset
Tires: Falken F452
Springs: H&R
even though you dont know the offset, i like the offset of the wheels that straight side pic is dope
Thanks Navy! Just did a little research, I believe they're +37
^^Did you have your tires stretched? I'm no tire guru, but I wouldn't think a 215 would fit an 8.5" rim
Why would you put smaller tires on your car?
it does with a stretch. If you look at the pic a little closer, you can clearly see that the tread cross section is not even close to the width of the rim.
I'm on my work computer, which has restrictions so I wasn't able to see the pic. But those specs WOW'd me...have to check out the goofiness when I get home haha.
Discussion Starter · #18 ·
Motegi 17x8 wheels +27 i think... Nexen 235-17's, funds were low AND i hated the stock wheels!! lol!!
I want a set of MR wheels in either flat black or gunmetal!! 255-17 maybe???
:rock:
welcome to the forums. :yay:
1 - 20 of 34 Posts
