So I figured I would start a thread regarding this...
I put on the Whiteline RCA kit at about 5k miles with my new Swift springs.
We are now at about 46k miles and finally the kit is worn to the point of needing replacing.
I needed to replace both outer tie-rods. The drivers side was the worst with over 1cm of play on the wheel laterally side to side.
The ball joint themselves are in WNL condition. But, the boots are starting to show wear and some superficial cracking. Again, I replaced the tie-rods. But I might as well replace the ball joints as well and replace the entire kit.
Again I drive through winter, summer, autoX, track, bumpy Cleveland roads. Again, I would have expected this kit to last longer. I am slightly disappointed in regards that it needs replacing so soon.
The tie-rods themselves has extreme amount of play in them... ball joints are still okay. Just worn down a bit.
Luckily I had a spare kit so I will just swap it. But it is just a warning to check your tie-rods since they do go bad even with "RACE" components.
