Hey guys,
I was following the HOW TO on datalogging AFRs on Evoscan using a serial port adapter and I ran into this problem over the weekend. Just a disclaimer: This is the first time i tried to do this and I am not a computer wiz so bare with me.
So i followed the intrustions to a T, but Im worried that one of my connections is not holding up.I soldered a wire (20 gauge) to the Blue wire from my AEM wideband and soldered that extention wire to the #2 pin on the serial port adapter, I then soldered a wire on pin #5 for ground. But i did have trouble getting a clean solder on the serial port connection since it was a tigh fit. This is where I think I have a possible connection issue.
When i try to find the COM port on Evoscan it does not want to use the serial port. It says it not compatable or something.
How do I know if its a bad connection or a not capatable adapter?
Any help would be appriciated!!
