1 - 2 of 2 Posts
Hi everyone.. running hks coilovers on Evo X 2015 GSR and in the market for ZE40s . specs for front wheels 18x9.5 and rear wheels are 19x9.5 both are +22 offset. Will I be able to run this setup?
I would strongly advise against that.
"Technically" if you get tires that have the same roll, it would work. But you will probably destroy your drivetrain by running different size wheels and tires.
You want to use the same size wheels and tires on any AWD car. Or you will end up spending thousands of dollars repairing the drivetrain.
But ZE wheels will fit with HKS coilovers. Just pick between 18's or 19's.
1 - 2 of 2 Posts
