E85 Spark plugs
1 reading
1.9K views 5 replies 3 participants last post by  flipntegra
#1 ·
What Plugs are yall running for E85 with a map turn to 93?
#5 ·
Here is my list:
Internals
Wiseco Forged Pistons 86.0 - 88.0mm bore
Manley H Beam Steel Connecting Rods
Ferrea Bronze Intake Valve Guides
Ferrea Exhaust Valves Valve Guides
Ferrea Valve Locks
Ferrea 6000 series Competition Valves
GSC Power Division Valve Stem Seals
GSC Power Division S2 Cams 274/274
ARP Main Stud Kit
ARP Head Stud Kit
Standard Race Rod Bearings Set
Race Main Bearings Set
Stock Mitsubishi Crank
MAP timing chain Tensioner Guide
Mitsubishi Timing Chain
Drivetrain
Clutch Masters FX300 Stage 3 Clutch Kit
Clutch Masters Aluminum Flywheel
AMS Performance Clutch Master Cylinder
Bolts ons
ETS 3.5 intercooler
ETS 2.5 intercooler pipes
ETS 3.5 MAF Housing
ETS test Pipe
ETS Dual Extreme Catback Exhaust 3 inch
AMS Performance Widemouth 02 Housing
Garrett dual ball bearing 3576 Turbo
Synapse BOV
Injector Dynamics 1300cc Injectors
Walbro 450 HP Fuel Pump
Walbro 450 E85 Install Kit
MAP AFPR Install Kit with AM Fuel Pressure
Regulator
Grimmspeed boost controler
I'm at 510 to the wheels on a mustang dyno, i'm starting to have some stuttering during 3k to 4k rpms. I Think my wideband may be the cause since i'm running at 15.6ish air/fuel if i'm wide open throttle i'm down to likes 11.5s air/fuel
#6 ·
Here is my list:
Internals
Ferrea Valve Locks
ARP Main Stud Kit
ARP Head Stud Kit
Drivetrain
Bolts ons
ETS 3.5 intercooler
ETS 3.5 MAF Housing
ETS test Pipe
Synapse BOV
Regulator
Stout setup. 11.5s is good and safe end. When is your car at 15.6? I hope not at WOT. I would log your car so you can see why its stuttering around 3k-4k.
