How much of a pain in the butt is the front sway bar to install in your garage? How long is this going to take me?
It appears you need to drop the sub frame, disconnect steering shaft, disconnect all the engine brace bolts to install the front sway bar? Has anyone installed the front sway bar at home using a floor jack?
I was reading the install from Hotchkis. Should I wait for the suspension shop do the front sway bar when they do the alignment for the springs? The rear looks pretty simple.
Thanks for the input.
