WORKS Diverter Valve - 2008+ EVO X
The WORKS Diverter Valve is an OEM-style unit featuring all-metal construction (except internal diaphragm). The DV utilizes a unique internal design to balance maximum boost pressure regulation while maintaining excellent drivability. Special fastening hardware ensures a superior airtight seal.
Holds upwards of 30psi (when properly installed) and since 100% of the discharged boost pressure is returned back to the intake, the WORKS DV ensures the best performance possible.
You cannot get a better EVO X valve for performance, reliability and daily drivability.
Application: '08 EVO X including GSR and MR
QUESTION
I say this is probably the best option for a recirc valve if you want to upgrade. Too many of these BOV cause a CEL to come on.
Just sharing some knowledge.
QUESTION
ANSWER
This is a good option for people who want to upgrade their BOV due to running higher PSI on various turbos.
