yes a search function would be good there has been alot of write up
the garrett guide will be a good start and the workshop manual will be good to look at for tq range.
make sure car is cold, soak it overnite, spray again just before u start taking things apart.
just a suggestion, mark or organize it in yr own way so u will know what is what and where things belongs to when you reinstall yr turbo.
few notes, be careful with 0-rings, oil lines cos they can break easily, hope you have a good selection of tools (breaker bar & angled 14mm wrench is a good start) alot of patience if not buts or bolts could be broken easily, get a buddy to help you out.
SAFETY SAFETY SAFETY ! make sure car is properly jacked & SECURED !
GL on yr install
