Hey guys,
Today i flashed gunzo's 90oct map and it knocked three times. From what i read, 1-3 counts is ok. My question is, is it still possible to run lean and not knock? I dont have a wideband and I'm not sure if Evoscan can monitor A/F ratios(just got it today). The car knocked once around 3300 (when it hits full boost) rpm and another time around 4500-4700ish. Is this ok? Maybe i can post the log on here so you guys can check it out for me and give me pointer on what to adjust? Also, i ran his 91oct map and the knock counts were similar to the 90oct map, BUT it showed that it knocked 9-12 times from 1300rpm-2300rpm (wtf?). Is this because when i shift or something??
