Perrin BOV *Thoughts* / Review
So I have a lot of things going on with my car and am down to making it all work together like the Smurfs picking berries. Myself and the infamous Joey "The Stig" Hauser are heading to PDX in February to fine tune our beasts on Surgeline's Mustang dyno.
With me being the paranoid anal engineer that I am.... I want to make sure the 16 hour round trip drive isn't a wasted one. So I am deciding to grab a spare BOV and right now from a simplistic design perspective the Perrin looks like a really good set up. It can be used as push or pull style and simplistic spring set up to ensure minimal issues.
Here is the design, let me know any experiences with this BOV or your thoughts on function and possible issues.
Also this PDF has a great little side cut away that shows everything pretty good.
http://www.perrinperformance.com/shared/PERRIN/documents/instructions/universal/asmint600.pdf
REVIEW
I have to say I'm impressed so far by the response and control of this BOV. I've tested it up to 33psi with no leaks or issues just holds tight.
There is a hint of stutter though if your right at the point of building boost and you feather the throttle. You almost have to try to make it happen though and I think part of the issue is a missing O-ring from my internal shuttle valve.
Really the benefit over stock is the ability to hold an infinite amount more boost. If your not running high boost levels than the stocker is your best bet but this one will look better :shades:
Side note this BOV can be set up in either direction. You'll notice in my pic above I set it up to have the boost hold the valve closed. This keeps the higher boost pressure from opening the pop off too early. So to summarize I'm very happy with its performance and so far no issues with this. :rock:
REVIEW
