SST Teach In
33K views 21 replies 13 participants last post by  Hispanic Panic
#1 ·
Recently, I upgraded the firmware of my 08 SST and performed a SST Teach-In according to Mitsubishi SST bulletin.
However, I gotten an abnormal end for the following 2 procedures:
#2 Shift Fork Teach In procedure - data error code of 0800
#7 Clutch Ventilation - No error code
On another friend's 08 SST, it only failed the #7 Clutch Ventilation procedure.
Both cars still drives well after the Teach-In despite 'failing' some procedures.
Any advise and more info on this would be appreciated.
Discussion starter · #3 ·
Hi Dan, yes I am doing it with the SST fluid warm up to at least 40 degrees Celsius as per the Technical Bulletin.
Upgraded my firmware to 8631B001.cff
The sequence for the Teach-In procedure is as follow:
No.1 -> No.2
Off Ignition
No.7 -> No.4 -> No.5 -> No.8
Also, I have left the firmware as it is after the Teach-In.
