WGDC correction adjustment question
5.8K views 21 replies 4 participants last post by  oftheheavens
#1 ·
ok so i am trying to change my WGDC table as golden instructed me to but i have a question.
he told me to adjust the WGDC table to the value that the correction was correcting.
so when i look at my logs i have something like this (just to show a couple example lines)
RPM WGDC WGDCCorr
2750 83.5 -9
3000 79.5 8
so with the examples above, should the 2750 WGDC table be taken to 92.5 or to 74.5? in other words does a negative correction mean to add or subtract from the WGDC table %?
same with the 3000 WGDC % should it be 87.5 or 71.5?
my main question is, how do calculate the total using WGDC and WGDCCorr?
thanks
#3 ·
so the correction number doesn't come into play at all?
so i just need to put the number that is in the WGDC_active column into the WGDC table?
#5 ·
my current 2750 is 71, that is why i am confused.
and my current 3000 is 76.5
#12 ·
No it sounds like he is saying:
logged value - table value = correction
excuse my ignorance, but what does the correction number do for me?
should i just replace the table value with the logged value? or do i need to do something with the correction?
#13 ·
ok maybe i just understood it, tell me if i am right.
it is supposed to be table value-correction value=logged value?
i used ecuflash
#15 ·
got it.
like i said in the PM, Golden has been teaching me over the last few months, and i am going to wait for his response before i flash anything to my ecu. But i am trying to learn as well so i thought i would ask here about WGDC and correction.
#18 ·
Ok. The issue here is that he has totally different tables in normal maps than his alt maps.
I think he is doing some pulls on the normal map and editing the alt maps.
I'll get it taken care of. I've just been really busy lately.
#19 ·
no worries golden, i knew you had to have been busy cause you usually get back to me fast, which is why i came here to find more knowledge.
i am 100% sure that i have only been running the alt map, and only adjusting the alt tables. Either way i am going to replace the WGDC table with what was on the logs.
#22 ·
0 0 0 0 0 21 26.5 62 62
0 0 0 0 0 21 26.5 63 63
0 0 0 0 6 21 26.5 66 66
0 0 0 0 9.5 21 26.5 87 87
0 0 0 0 14.5 21 26.5 83.5 83.5
0 0 0 0 14.5 21 26.5 79.5 79.5
0 0 0 0 14.5 21 26.5 78.5 78.5
0 0 0 10 14.5 21 26.5 78.5 78.5
0 0 0 10 14.5 21 30.5 80.5 80.5
0 0 0 10 14.5 24 34.5 84.5 84.5
0 0 0 10 20 30 40 87.5 87.5
0 0 0 17.5 25.5 35.5 44 94.5 94.5
0 0 0 25.5 32.5 41.5 49.5 96 96
0 0 0 34.5 40 48 56 97.5 97.5
0 0 0 42.5 47.5 54.5 62.5 97.5 97.5
0 0 0 50.5 54.5 60.5 68 97.5 97.5
here is what it looks like after the changed to match the log
