A little background first,
2008 GSR (bought in January)
36xxx miles
Full bolt ons
Rickerman basemap (can't continue tune with Chet until I get this issue resolved)
I've been popping P0014 and P0011 CELs (exhaust and intake VVT system target error). I've replaced the oil control solenoids, cam sensors, and ECU. Timing chain is new, oil passages are clear, MIVEC sprocket mechanisms are manually operable.
Judging from my logs of target vs. actual on the cams, it seems MIVEC is not changing the phase angle of the cams. There's a hell of a lot of sloppily applied RTV on my timing chain case and oil pan, I guess from the timing chain install. I'm wondering if the oil feeder filter being clogged could cause this and also what's needed to check/replace it?
Quick log from tonight attached. Just check out the target vs. actual VVT
Thanks
36xxx miles
Full bolt ons
Thanks
