1,121 - 1,128 of 1,128 Posts
well 6 out of the 7 bolts went in and the 7th was offset by like .08 inches. It became frustratingly obvious when that last bolt couldn't line up to thread into the block. I debated milling out the bolt hole on the flywheel but decided against it as the flywheel was already balanced and i had no way to balance it after machining. So i took pics of the misaligned bolt holes with calipers, sent it to fidanza, and i had a new flywheel the next day.
Ok gottcha.thanks !
I can tell you that removing the airbags from the dash along with gutting out all of the vents behind it and stereo equipment etc drops a good chunk. The dash is less than half as heavy once gutted.
Wow. This thread sure died off. Anything new? Hell, is there anything else at this point?
