41 - 60 of 254 Posts
Discussion starter · #42 ·
it looks like Hawk HPS pads are the way to go if you want street use
Meh im using HP+ for DD on street. Once they bed in well they are quite docile. :D
Nope. Hawk makes pads for the Evo X so no rear pad adapters.
I know this might be a dumb question, but can i jack up one corner at a time and change the brake pads? Thanks
Pad thickness is the industry standard where less than 3mm is time to replace. Heat will transfer faster with a thinner pad (from the rotor friction surface to the caliper piston/brake fluid).
True, ideally new pads should have a new smooth surface to run against. However whether the rotors need to be turned depends on their condition: warpage amount, depth of grooves, lip, hot spots, etc.
Unfortunately the stock rotors don't leave much for clean-up machining - there is a max of 1mm that can be taken off - including wear. So if the surfaces will clean up with 0.020" taken off each side (including wear), then you're good to go. otherwise it's time for new rotors also.
While the worn rotor may be OK (not ideal, but usable) to keep on going, it will probably be too thin after machining.
And since it's not a fifty dollar rotor...
I found $50 rotors for the X. Wish me luck!
Discussion starter · #53 ·
Linky? Name, brand, type, weight? Info mang info! :)
I got $50 rotors for the X from a brand "Winhere", from partsgeek.com 25lbs, blank for the fronts; I don't remember the weights of the rears, I can put them on a scale later today and weight them more precisely. Nicely milled though. I matched them up to the OEM ones that I had off when turning, and they look identical. Unless they did something illegal and blatantly wrong (i.e. too high of carbon content or something), they ought to be ok, but I'll be toting my OEM's around the whole first week I try them out. Partsgeek carries some decent rotors for the 8 and 9, so I figured I could be a guinea pig for them.
thanks much for this write-up.
swapped out my fronts today with the Hawk Ceramics and this definitely made it easier, and made the work more confident.
one thing that happened (or had already happened, can't really remember now), is the following:
the retention clip is shearing off, not quite broken through yet and still holds everything, but is definitely not as tight as the other ones due to this "crack".
has anyone else come across this?
any suggestions on a good place to get a replacement? i'm sure i could get one from the dealer, but can't imagine they'll give me a good deal.
any help would be great.
thanks,
Ryan
also a pretty good picture:
definitely scary thin! glad i got around to it when i did.
how many miles on that worn pads?
thanks,
Ryan
Discussion starter · #60 ·
Wow horrible thin pad. Glad the how-to helped.
