if you only bore the block, reving the engine past 8k will not cause problems, as the rod:stroke ratio is the same. So what is good for a 2.0 is fine for a bored 2.2l
stroking the engine cause higher pistons speeds, as the piston is traveling a greater distance and therefore needs to move faster for the same cycle. which is why you would want to lower the redline.
basic on stroke, rod length etc.
http://www.hotrod.com/howto/69883_stroke_any_engine/
how much faster will it spool is easy for any given turbo, x displacement is required to spool for a certain rpm. if you increase displacement 10%, you relatively need the same percentage less to spool the turbo.
so if it takes a 2l engine 4k rpms to spool x psi
if you increase the displacement 25%, the new engine should spool the turbo 25% faster or @ 3k rpm, these are relative assumptions, assuming the only variable which changed is displacement.
